Mark65
Jun 06, 2015Aspirant
WN1000RP fails at last step of setup
I'm trying to get the WN1000RP set up with my Linksys WRT54G router. It completes all of the steps of the setup process except the last one where it gives me an error that it lost contact with the ro...
Babylon5
Jun 07, 2015NETGEAR Employee Retired
Are you sure that the login screen you see is for the extender and not the base router, is it asking for Username/Password or SSID/Passphrase? Are you absolutely sure that the computer is connected to the Extender and what you are seeing is not just cached browser data? Are you doing all of this with the computer only connected wirelessly to the Extender and not with a wired connection to the LAN at the same time?
