jamesallen
Nov 06, 2015Follower
WN1000RP issue
Hi all, I've followed the setup instructions for the WN1000RP wifi booster. It connects without any issue to the router via the WPS setup but when I try to access the _EXT network it repeatedly tell...
rakesh-net
Feb 09, 2016Aspirant
my netgear not open I forgot paasword
- DarrenMFeb 11, 2016Sr. NETGEAR Moderator
Hello rakesh-net
You would need to do a factory reset as nhann posted above after that you should be able to login to the extender with the default login of admin/password.
DarrenM
