GaryW14's avatar
GaryW14
Follower
May 21, 2020
WN1000RP. Only the middle light is green; the other two are dead. What's wrong please?
I've had the netgear booster a number of years and it's worked ok.  Then this morning I just get the one middle light green, the upper and lower indicators are dead.  I've tried switching the booster...
  • plemans's avatar
    May 21, 2020
    So the middle one is the status light. green means its powered on. if the other 2 are off it means
    top: link rate---not connected to the router
    bottom-device light-its not connected to any devices.
    you can try resetting the extender and reinstalling it.
    https://www.netgear.com/support/product/WN1000RP.aspx
