AdrienMcG
Jul 15, 2018Aspirant
WN2000rpt Smart TV box wont connect , everything else will
I have just purchased a range extender. I set it up using my phone. I get signal on my phone , no problem. However I cannot get my TV smart box to connect properly. .
It shows the range extende...
- Jul 17, 2018
Hi AdrienMcG,
1. You can find the firmware version by accessing the extenders UI using the IP address assigned to it by your router.
2. To confirm, does the extender show up as a connected device when you access the main router's UI?
3. The wireless channel settings will be on your main wireless router's UI.
Dexter
Community Team
DexterJB
Jul 16, 2018NETGEAR Moderator
Hi AdrienMcG,
Welcome to the community!
1. What is the firmware version of the extender?
2. Does the MYGICA 495 Max successfully connect to the extender's signal?
3. Have you tried resetting the extender?
4. Have you tried changing the wireless channel?
Dexter
Community Team
DexterJB
Jul 17, 2018NETGEAR Moderator
Hi AdrienMcG,
Dexter
Community Team
