rjamisn
Oct 22, 2016Aspirant
Wn2000rpt stuck in loop
This unit ran fine for 3 months then out of the blue would not connect. I have reset to factory settings several times. Will not connect with WPS, tried that. When you try the smart set up which is...
DarrenM
Oct 24, 2016Sr. NETGEAR Moderator
Hello rjamisn
Did you recently update the firmware or a lightning storm caused a power issue?
DarrenM
rjamisn
Oct 25, 2016Aspirant
No storms here in the last couple weeks and did not update firm ware, was already running the latest. It just started this out of the blue. You are probably right does seem like a power cycling issue. Just found out from Best Buy they said it is a discontinued model, now I know why. It always did seem to run warm, guess after a few months the heat finally got to the power supply. Once bitten twice shy. Thanks
