optodata
Aug 22, 2012Aspirant
WN2000RPTv2 connection issues
I'm having trouble reaching the internet through a WN2000RPTv2. It has the latest firmware (1.1.0.12) and my Win7x64 laptop shows internet connectivity and Home Group access, but I cannot reach any webpages, including mywifiext.net or .com. (I get an instant redirect to http://kbserver.netgear.com/products/wifiextdevice.asp with a 404 error on that web page).
I am able to communicate with the extender at 192.168.1.250, but if I try to check for firmware updates from the extender I get a "No Internet Connection" message.:confused:
Can anyone give me some suggestions?
- jmizoguchiVirtuosomake sure to use WPA2 encryption
- optodataAspirantI'm using WPA2-AES. The main router is a 2wire 802.11b/g DSL unit from ATT. There are quite a few nearby WiFi networks, and the I'm using CH1 because the closer neighbors are using channels 6 and 11.
All the settings in the Netgear extender match those of the main router, but no joy on internet access. Are there any othe settings that would be helpful to know? - jmizoguchiVirtuosotry putting google DNS on pc side which is connecting to extender
- optodataAspirantOK. I'll put 8.8.8.8 and 8.8.4.4 as the DNS servers on the laptop's network settings when I get home and see if that works. That wouldn't seem to affect the extender's inability to access the internet (to check for firmware updates), would it?
you can always go to support.netgear.com to find latest firmware as well - optodataAspirantAdding the Google DNS servers didn't change anything. The Win7 laptop is connected to the network and the Home Group, but it still can't access the internet.
We also tried an iPad through the extender and it would start to load a webpage, then it stopped with a meessage that the server had stopped responding.
It seems that the internet is reachable but there's almost no throughput and/or the connection keeps breaking. I'm going to see if I can get anywhere with NetGear tech support. - jmizoguchiVirtuosoplace the extender closer than current location
- milroseAspirantI thought this would be easy. mywifiext.net is mythical. Doesn't exist. Not sure why that website is even listed in the installation guide. I can get the extender to work but 3 weeks of trying to get it secure has failed. The netgear genie shows up (only one time and it too has gone by the wayside) but I can get about halfway through the setup and it freezes and then quits. I'm on an iMac but have also tried using windoze.
I'm trying 1 more day and then I'm switching to another brand. 3 weeks of trying has taken it's toll. - allien92AspirantPour une bonne installation, les informations fournies dans le manuel sont efficaces (personnellement, j'ai choisi de garder mon reseau avec l'extension _EXT, soit.... MONRESEAU_EXT), Il suffit de les valider jusqu'à la page où il vous est demandé de fournir le niveau d'encryption, la Phrase d'authentification et les clés...
A ce niveau, il faut choisir le même niveau d'encryption que celui enseigné lors de l'installation de votre box (64 ou 128 bits).
Il ne faut pas indiquer de phrase d'authentification.
Puis vous indiquez le même mot de passe ou, le cas échéant, la clé wep réseau de votre box.
Ensuite, vous cliquer sur continuer.
Un message vous demandera d'entrer à nouveau votre mot de passe/clé wep du réseau. Il suffit d'entrer le mot de passe ou clé wep indiqué précédemment.
Et vous devriez avoir 3 voyants verts qui s'allument, sur l'amplificateur, en plus du voyant WPS... indiquant votre connexion sur le réseau amplifié.
C'est fait. - jmizoguchiVirtuoso
allien92 wrote: Pour une bonne installation, les informations fournies dans le manuel sont efficaces (personnellement, j'ai choisi de garder mon reseau avec l'extension _EXT, soit.... MONRESEAU_EXT), Il suffit de les valider jusqu'à la page où il vous est demandé de fournir le niveau d'encryption, la Phrase d'authentification et les clés...
C'est fait.
Just let you know this forum is english base so you may have less people reply to your post if it was not in english. :)
