Tomsys
Oct 19, 2015Follower
WN2000RPTv2 connection issues
I installed the extender according to the instructions but i cannot connect from any device. PCs do find the extended line but the connection is poor, which is really null. Smart phones keep searching for the ip address eternally. I tried moving the WN2000RPTv2 to different areas, but its the same. The password isn't the problem either. im about to throw the damn thing through the window....
1 Reply
- nhannNETGEAR Employee Retired
Hi Tomsys,
Which router is connected to the WN2000RPTv2?
Are both the router and extender updated to latest firmware?
http://support.netgear.com/product/WN2000RPTv2How is the connection of the extender when placed in the same room as your router?
You can also try switching your WiFi channel if there are interfering networks:
http://kb.netgear.com/app/answers/detail/a_id/23783/~/improving-2.4ghz-wireless-performance-by-changing-channelPlease try setting up the WN2000RPTv2 via WPS (or web browser setup if WPS was previously used)
Press and hold the Restore Factory Settings button on the rear panel for 7 seconds. The extender resets, and returns to its factory settings.
