Wurzelmuc's avatar
Wurzelmuc
Novice
Mar 31, 2015
WN2000RPTv3 - DLNA-problems
Hi there,
I have a AVM FritzBox 7390 (DSL modem + router) and a cable bound Synology DS215j as MediaServer on the one side...and the Netgear WLAN-Extender + a cable bound Samsung-TV on the other side.
My problem is, that being connected to the WN2000RPT (either the TV or with my notebook in the ..._EXT-wifi), the Synology is listed as a DLNA-Server, but doesn ́t provide any content.
If I connect the TV or my notebook to the FritzBox, everything is fine and the content can be accessed. The wifi-extender is basically just a "cable replacement", because the room really doesn´t allow to install an ethernet cable in a visual acceptable way.
Do you have any ideas, what´s going wrong there and especially what I can do to solve that? :)
Thanks in advance and greetings,
Jörg
1 Reply
  • Hi,
    I tested a little bit more...and the results confuse me also even more to be honest :)
    I established a cable connection between the extender and the fritzbox router....and also a cable between the TV and the extender. My notebook uses the ..._EXT-wifi.
    I can play DLNA content on the TV and the notebook this way. So basically it´s all there to have it functional. But what has to be done, to get rid of the cable connected between extender and router and still have that working?
    I´m really lost and would be absolutally happy for any help on that !!!
    Greetings, Jörg
