Robsgear
May 15, 2017Aspirant
WN2000RPTv3 firmware for Windows 10
Hi all, Having been away from home for some time, when I try to connect my Netgear WN2000RPTv3 to my PC running on Windows 10 I get a message saying it is not compatible with Windows 10. On further...
Robsgear
May 17, 2017Aspirant
Hi,
Thanks for your reply. Unfortunately, as I said in my initial post, whenever I download the link and then try to open it I get a message telling me that the disc image file is corrupted.
Regards
Rob
TheEther
May 17, 2017Guru
You are only supposed to unzip the zip file and image file within to the WN2000RPT. You are not supposed to open the image file.
