Spacebridge
Sep 03, 2018Aspirant
Wn2000RPTv3 internet issue
Someone help please before I go nuts my extender wn2000rptv3 isn’t working properly I reset the damn thing 10 times and went through the process 10 times and it works normally but when I connect my ps...
Sep 03, 2018Guru - Experienced User
The router link LED is green, but you are seeing no internet connection?
Is the extender in AP mode or Extender Mode?
Is the PS4 connected to an extender LAN port, or is it connected to the extender's wifi network?
Spacebridge
Sep 04, 2018Aspirant
All are green it’s in extender mode and the ps4 was always connected wireless to it
- StephenBSep 05, 2018Guru - Experienced User
- Can you connect a different device to extender wifi, and see if that behaves the same way?
- Can you run ethernet from the extender to the PS4 (temporarily)?
It's possible the issue is in the PS4, not the extender - the above suggestions would help isolate it.
- SpacebridgeSep 05, 2018AspirantI’ve tried that too it’s the extender it’s self my computer doesn’t get internet when it’s connected to it I’ve even tried the eithernet cable on both ps4 and pc and still nothing
Ok. Have you looked at the extender web page, and double-checked if it is connected to the correct router network?
