OddMolly's avatar
OddMolly
WN2000RPTvs3 no reconnection to mobile
I installed a WN2000RPT (vs3) N300 WiFi extender some days ago and the installation worked fine and so did the extender, which connected perfectly to the base WiFi. All mobiles, computers etc connect...
  • nhann's avatar
    nhann
    Oct 19, 2015
    Thanks for the clarification OddMolly.
    Can you please try setting the network to a different Security mode?
    For example, try No Security then WPA2 (switch to this if you are currently on WEP)
