timfd
Feb 25, 2018Follower
WN2500RP- cell finds 2G & 5G bands fails to connect, after change to Fastlane Tech
Model WN2500RP extender and FIOS-G1100 dual band router. I used www.mywifiext.net to connect extender to 5Ghz band of router. That created extender networks FIOS-GARI5-5G_5GEXT and FIOS-GARI5-5G_2GEXT...
jvasanth1984
Feb 28, 2018Virtuoso
Hi timfd,
Locate the reset hole at the back where you connect the cables to it and hold it for 15-30 seconds inorder to reset it to factory settings. Then you can set it up again.
