Lehnen
Dec 23, 2024Aspirant
WN2500RP broken
Hello, my WN2500RP is broken. Among other things, component Q3 (marking: F42A) is broken and I would like to replace it. Can anyone here tell me exactly what this component is? Best regards
Dec 26, 2024Guru - Experienced User
you did a lot more on a dropped/non-working device that is over a decade old than I would have.
Lehnen
Dec 29, 2024Aspirant
Yes đ But I enjoy repairing things like this. It's a kind of hobby.
So if I can repair the device I can write what it was, if anyone is interested. Some other guy said the component could be the AO6604 mosfet by A&O. I think I will try it out and report back.
Thanks so far
- balky1020Jan 15, 2025Tutor
I have same problem after it got moist. ive been using this device for maybe ten years on a tall pole and the only protection has been a ziplock bag upside down so the rain doesnt go inside. Finally a creature or a big pine cone moved it
same boot problem, orange light always on
sometimes it switched off on its own
go netgearl
- plemansJan 16, 2025Guru - Experienced User
Good god. That's the jankiest "weatherproofing" I've heard of in a long time. Totally reminds me of the beer can shower head. And then I'm picturing a nut chaser messing with it or even causing the moisture. I'm impressed it lasted this long.
Netgear doesn't make a current version but there are pretty solid outdoor rated extenders out there. Might be time to actually invest in one for that purpose đ
- LehnenJan 17, 2025Aspirant
So I soldered the component in. There is now 1.2 V at the output (pins 4+6). Unfortunately, the extender is still not working correctly. The diodes light up as follows (all continuous):
D909, WPS: off
D904, 903, 902, 901, LAN ports: green
D910, connection to WLAN device: green
D916, Link Rate 5 GHz: red
D907, Link Rate 5 GHz: off
D915, Link Rate 2.4 GHz: red
D905, Link Rate 2.4 GHz: orange+green
D906, Power: orangeA button reset does not change anything.
So the troubleshooting goes into the next round.
