AFG034
Nov 28, 2015Aspirant
WN2500RP connecting issue
I've installed the Netgear WN2500RP correctly, I see the signal but none of my devices (iPad, iPhone, MacBook Pro and Apple TV) will connect. I enter the password and it just thinks but never connec...
TheEther
Nov 28, 2015Guru
Is the extender establishing a connection with the router?
Are you using WPA2-PSK [AES] security?
Do you have a MAC Access List set up on either the extender or main router?
