flamonica
Sep 02, 2015Aspirant
wn2500rp connecting with username and password
Hello, i have a wn250rp range extender and i'd like to know whether it's possible to connect to a wifi network that requires for username and password. I have not found any way to insert the usernam...
flamonica
Sep 03, 2015Aspirant
Yes, that is most probably the case, is there a way to connect the repeater to such network?
thanks
Babylon5
Sep 03, 2015NETGEAR Employee Retired
I can see nothing in the User’s Manual that mentions 802.1x authentication and I would expect that it would need that option to associate with the base station, so it seems that it cannot be used to extend an authenticated network. I will check with Netgear to see if that’s the case,
