zipdrive
Mar 13, 2016Tutor
WN2500RP Keeps Disconnecting
I have the WN2500RP (Firmware Version V1.0.0.30_1.0.58). This unit is constantly disconnecting from my Netgear R6100 router. For the record... the router's firmware is the latest.. V1.0.1.10. I h...
robbchappa
May 31, 2016Aspirant
My wn2500rp worked great for years then did this very same thing. So I bought a brand new one. It does the same exact thing. So I returned it and bought another. Same exact thing so I doubt its the extender. Common denominators is my original extender worked fine until I upgraded firmware all to 1.0.30. All three are running this version so it has a major problem and now I can't roll it back because the unit doesn't stay up long enough to flash older firmware. So I have 2 useless extenders and netgear hasn't done a damn thing to address this. Why would anyone buy any newer products when they won't support something they broke??? Anyone?
- DarrenMJun 06, 2016Sr. NETGEAR Moderator
Hello robbchappa
Have you tried to connect via Ethernet to roll back the device? Also have you tried to factory reset the extender?
DarrenM
