zipdrive
Mar 13, 2016Tutor
WN2500RP Keeps Disconnecting
I have the WN2500RP (Firmware Version V1.0.0.30_1.0.58). This unit is constantly disconnecting from my Netgear R6100 router. For the record... the router's firmware is the latest.. V1.0.1.10. I h...
robbchappa
May 31, 2016Aspirant
My wn2500rp worked great for years then did this very same thing. So I bought a brand new one. It does the same exact thing. So I returned it and bought another. Same exact thing so I doubt its the extender. Common denominators is my original extender worked fine until I upgraded firmware all to 1.0.30. All three are running this version so it has a major problem and now I can't roll it back because the unit doesn't stay up long enough to flash older firmware. So I have 2 useless extenders and netgear hasn't done a damn thing to address this. Why would anyone buy any newer products when they won't support something they broke??? Anyone?
DarrenM
Jun 06, 2016Sr. NETGEAR Moderator
Hello robbchappa
Have you tried to connect via Ethernet to roll back the device? Also have you tried to factory reset the extender?
DarrenM
