al1974
Jan 19, 2016Follower
WN2500RP range extener not working
had this for a while and has worked perfectly. Upgraded to windows 10 and now doesnt work. Cant access mywifiext.net even though its connected. Is there some trick to connecting to Windows 10? Have d...
Babylon5
Jan 19, 2016NETGEAR Employee Retired
You will only be able to access mywifiext.net using a wireless connection if the computer is wirelessly associated with the router, and not the base station. Have you tried connecting to one of the repeater’s LAN ports using an Ethernet cable?
