makinworks
Feb 23, 2017Aspirant
Wn2500rp slower bandwith than WNR2000v4 Router
Wn2500rp slower bandwith than WNR2000v4 Router I do speed test from the Wn2500rp and it is half the speed of when connecting to the main wnr2000v4 router...is this correct? or am I not setting th...
DarrenM
Feb 24, 2017Sr. NETGEAR Moderator
Hello makinworks
When you use a wireless extender you are going to have speed loss up to 50% you may want to adjust the wireless channel in the wifi settings of the router to try and improve the wireless speed on the extender.
DarrenM
