bpcass
Sep 10, 2018Aspirant
WN2500RP WiFi Range Extender cannot configure to new WiFi
Hey there Netgear Community, I can’t seem to connect to a new network with the WiFi range extender. I’ve gone through all the message boards and suggestions, I’m suspecting that mywifiext.net is down...
Sep 13, 2018Guru - Experienced User
To be clear - mywifiext.net should get you to the extender web page (which is hosted in the extender itself). If you aren't on the extender network, then it will take you to a placeholder internet page, that tells you that you aren't connected properly. So if mywifiext.net is down, then either the extender itself is down, or you aren't connected to the extender wifi network.
Try resetting the extender by pressing and holding the "restore factory settings" button for 7 seconds (see page 6 in the manual if you need help locating this). Then set the extender up again. http://www.downloads.netgear.com/files/GDC/WN2500RP/WN2500RP_UM_9Nov12.pdf
bpcass
Sep 14, 2018Aspirant
Problem solved, thanks!
