btmblue
Mar 19, 2018Follower
WN2500RPv2/N600 Dual Band Issue - 2.4ghz network keeps dropping
I am having major issues with my wireless network. This extender keeps dropping the 2.4ghz network for some reason. It keeps the 5ghz connection with the router, however, I have to keep rebooting the...
DarrenM
May 03, 2018Sr. NETGEAR Moderator
Hello Sheiweesh
Have you tried to adjust the wireless channel on your router?
https://kb.netgear.com/25182/Resolving-poor-5GHz-wireless-range-signal-from-my-NETGEAR-router
DarrenM
- SheiweeshMay 03, 2018AspirantHi, that link is for the 5Mhz, which I do not have enabled. Is it the same for the 2.4Mhz? I read a lot in the past about differences between the two and thought I did good by moving the 2.4Mhz to 11. It does have an Auto setting but what I read a while back advised against it as the switching may cause interruption. What just said is for my router. The problem is with my extender which is set to match the router at channel 11 for the 2.4Ghz. What’s your recommendation?
- DarrenMMay 03, 2018Sr. NETGEAR Moderator
Yes follow the same process as in the 5ghz KB and the extender will follow the router but it could make the signal between the two better which may improve your issue.
DarrenM
- SheiweeshMay 04, 2018AspirantHi,
I used a scanner on my computer near the router and I’m the only one using #11. There are only a few other SSIDs in the area. I switched to #3 for some time but that didn’t help. I still had to restart the extender. Then I switched to Auto and it looks like it used #11 on its own. This morning I still had to restart the extender.
Do you have any other suggestions? Thanks for your help.
