CHUCK12351's avatar
CHUCK12351
WN3000 V2 FIRMWARE CORRUPTED ALL .CHK FILES NOT .IMG
V3 DOWNLOADS AN IMG FILE BUT V2 DOESNT. ALL FIRWARE VERSIONS.THE UPDATE WILL NOT TAKE A CHK FILE OR  A FILE RENAMED TO IMG.
  • CHUCK12351's avatar
    CHUCK12351
    Jul 06, 2016
    well looks like the server web site is working now .
    There are 2 web sites to get the new firmware?    http://downloadcenter.netgear.com/     with the drill down
    This gives  Firmware Version 1.0.0.36   which is an IMG file and it loaded! server now says 1.0.0.36 is the latest.firmware
    The other is http://www.netgear.com/support/product/WN3000RPv2  This site gives a newer version but its WN3000RP-V1.0.2.64_1.1.86.chk
    Its a chk file.The release note even says its a chk file.
    But  http://www.mywifiext.net.  won't accept it.  Popup says " Please assign the correct file.The file format is "*.img""
    Changed it to .img. No GO .
    Please fix this site.
    You need to fix this
