nicferrier
Dec 10, 2013Aspirant
WN3000P security problem with an N300
I'm trying to get a WN3000P to extend a network provided by an N300 router. The N300 is configured with a passphrase 64 bit WEP key (as opposed to a hex key). When I configure the WN3000P I can...
jmizoguchi
Dec 11, 2013Virtuoso
Some of the updated pc no longer take WEP and when it ask for passphrase like this way wether hex or ascii. the character length is different
You will going to have issues with devices start drop WEP usage as over decade old encryption. Should consider to change for fact you are making difficult to communicate based using behind technology
