scottwhatever
Mar 17, 2015Novice
WN3000RP - shared house question
HI, I currently live in a bedsit with about 25 rooms, 3 floors, and has Wifi with Virgin Media. The router is on the first floor and I'm on ground floor. The signal is very poor, in fact neglible. ...
Babylon5
Mar 18, 2015NETGEAR Employee Retired
Your use of a range extender will have negligible effect on other users, however I don’t think it will meet your expectations given the position you plan to use it in. For a range extender to propagate a good throughput to its clients it needs to be in a position where it will receive a good throughput itself from the base station.
I would suggest that you consider Powerline products, some of which provide a WiFi Access Point at the remote end;
http://www.argos.co.uk/static/Search/searchTerm/powerline.htm
