scottwhatever
Mar 17, 2015Novice
WN3000RP - shared house question
HI, I currently live in a bedsit with about 25 rooms, 3 floors, and has Wifi with Virgin Media. The router is on the first floor and I'm on ground floor. The signal is very poor, in fact neglible. ...
Babylon5
Mar 25, 2015NETGEAR Employee Retired
It will have no more effect on data rates for the others than if you directly connected to the router, which I assume you are allowed to do. The access point / repeater / Powerline product or whatever you choose (are allowed) to use will not increase your use of data beyond what it would otherwise be.
