APM1949
Aug 11, 2015Aspirant
WN3000RP & BT Home Hub 5
When try to connect my WN3000RP in to my network everything works according to the set up until the last step. At that point the Netgear Genie tells me " The Extender was not able to connect to your existing network". Can anyone explain what is going wrong or are the two devices incompatible??
Many thanks.
- nhannNETGEAR Employee Retired
- APM1949Aspirant
Many thanks for your prompt response. I don't think it it is a password problem, I use the same one as for the rest of my home network generated by Windows 8.1 and now Windows 10
The model number is WN3000RP V1H2.
Andrew
Hi APM1949,
Are you able to reach this stage of installation?
Once you are at this step, you will need to connect to the new SSID, then click continue.
