unknown2u's avatar
unknown2u
Follower
Jul 18, 2018
WN3000RP-100nas
I just bought the basic wifi extender - to get better wifi in my basement .
I have just spent an hour trying to get it to hookup. the wps light only blinks, then goes out after a couple of minutes.
I tried the website - www.mywifiext.net - it will not load.
I registered the extender with netgear in hopes to chat for support - that does not appear to exist either!!
I finally got to this site.
I am about to return it as a lost cause - anyone that can help me ??
  • Hi unknown2u,
    Welcome to the community!
    1. This link for the installation guide may help.
    2. Please make sure that the extender is close to the router that supports WPS.
    3. Please make sure that you are connected to the extender's WiFi before going to www.mywifiext.net.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi unknown2u,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi unknown2u,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
