pdneri
Aug 06, 2016Follower
WN3000RP and captive portal
I succesfully connected to a wifi that requires login through a captive portal. Each device needs to login. Unfortunately some devices like TVs and Consoles cannot connect this way.
I am wondering if there is a way to login once within the extender menu and let all devices access without login.
Thanks
Thanks
1 Reply
It's kinda of a kludge, but try connecting a router to the WN3000RP. Then connect your devices to the router. To the captive portal, it will look like only one device is attached (i.e. the router).
