Thomas13
Feb 13, 2016Follower
WN3000RP can not connect to FIOS Gateway Quantum Router
I upgraded to FIOS 75/75 and received a new router, (Verizon Gateway Quantum). After doing the Factory reset on the extender I've been trying to re-configure the extender to the new network, with no...
edwardb226
Apr 19, 2016Aspirant
I too have the same problem.
I had no problem connecting to the previous router, Actiontec, but can't connect to the
FIOS Quantum Router.
I tried everything.
- DarrenMApr 27, 2016Sr. NETGEAR Moderator
Have you guys tried using WPS to connect? also try to do the setup while connected directly to the extender via Ethernet.
DarrenM
