Thomas13
Feb 13, 2016Follower
WN3000RP can not connect to FIOS Gateway Quantum Router
I upgraded to FIOS 75/75 and received a new router, (Verizon Gateway Quantum). After doing the Factory reset on the extender I've been trying to re-configure the extender to the new network, with no...
edwardb226
Apr 19, 2016Aspirant
I too have the same problem.
I had no problem connecting to the previous router, Actiontec, but can't connect to the
FIOS Quantum Router.
I tried everything.
DarrenM
Apr 27, 2016Sr. NETGEAR Moderator
Have you guys tried using WPS to connect? also try to do the setup while connected directly to the extender via Ethernet.
DarrenM
