JaneH
Apr 03, 2014Aspirant
WN3000RP connection question
I've had my Netgear Universal WiFi Range Extender, Model WN3000RP for several months. I set it up with minimum effort. Now however (drum roll, please), I changed ISPs and my WN3000RP now is not recogn...
marc311
2arrows=off means you dont have a device connected wired/wireless on the extender maybe that is the factor why you cant access the user interface sir.
since you have new ISP(I assume you have new modem+router) that means also the extender is needed to be reconfigured to get the new settings of the new modem+router.;)
try to check this link for PDF manual.
http://support.netgear.com/product/wn3000rp#wrapper
