Dash-
May 05, 2017Aspirant
WN3000RP dropping connection
I have small issues (Until the wife's device fails). The WN3000RPv2 will go along nicely for awhile, then internet gets slower, if I ping it, it starts dropping packet returns- 80%-90% in some cases...
DarrenM
May 16, 2017Sr. NETGEAR Moderator
Hello Dash
Have you made sure its on the latest firmware? also you may want to move the extender to a different spot.
DarrenM
- Dash-May 21, 2017Aspirant
Yes, to both answers, currently it is within reach as I sit and type this. The current updates are all performed first to try to correct this, on the rule-out of old problems. However, the problem continues across multiple devices and operating systems.
ON a "PS" I failed to note, if I am connected via ethernet Cat5 cable to the WN3000RP, the connection is good for that one device.
