julianfoster
Oct 15, 2014Aspirant
WN3000RP dropping connection
Hi, I have just purchased the WN3000RP extender. Very easy to setup and get working, however after a period of time or overnight the connection to my router appears to have been lost. The devices (...
givemesam
Jan 30, 2015Aspirant
I am having the same issue.
it basically drops one client at a time, on both 2.4 and 5ghz interfaces.
They do not directly correlate. So one client will drop, then try to reconnect after a few seconds, then another client will do the same later.
I am using the most current firmware. Will not downgrade and test again.
