WhiteDelight
Dec 02, 2015Follower
WN3000RP extender stopped working, please help
Hello, so basically, I bought the extender 3 months ago from Best Buy, and the setup was fine and it worked great up until a week ago. For some unknown reason, I can connect to the extender fro...
nhann
Dec 03, 2015NETGEAR Employee Retired
Hi WhiteDelight,
Can you please confirm which WN3000RP you have? v1, v2, or v3
http://support.netgear.com/product/WN3000RP
http://support.netgear.com/product/WN3000RPv2
http://support.netgear.com/product/WN3000RPv3
Also, login to your extender's network by going to mywifiext.net
and check which firmware version you have.
On your laptop, try forgetting/removing your Extender's WiFi network. Then reconnect to the Extender's WiFi.
Is your laptop able to connect to the Router's network?
