Kazatan
Mar 08, 2016Aspirant
WN3000RP extender via ethernet?
Hey guys, I bought a NETGEAR WN3000RP a couple of years back and never got around to using it on a permanent bases as it was never providing a stable connection, I am wondering if what i want is ...
Kazatan
Thanks for the response, However the manual instructions is different to the user interface of www.mywifiext.net.
My exact model is this:
http://support.netgear.com/product/WN3000RP
Looking at the manual, i unable to find anything about an access point setup - the only options in the interface are for wireless setups, all the help is appreciated.
TheEther
Mar 09, 2016Guru
Bummer. It looks like Access Point mode may not be available in your version of the WN3000RP. Are you running the latest version of firmware?
