ravidesai1406's avatar
Dec 08, 2021
WN3000RP Link Status is blank
Team,
My WiFi extender was working perfectly fine till yesterday. However, suddenly the LINK STATUS light has gone blank.
I tried everything, including factory reset and connecting all again.
Please help how to solve this issue - extender is an important part of our family in these WORK FROM HOME times.
Ravi
  • There was some issue with my main WIFI ... That got resolved and the extender is working perfectly fine.
  • plemans's avatar
    What router are you connecting it to?
    what method of setup are you using? WPS or the installation assistant?
    • Router - Tp-link wireless router
      Method - installation assistant through windows
      • plemans's avatar
        what tp-link router? They make a lot of them.
        During setup, is the extender able to see the tp-link's wireless?
        What does it show on its status page after it goes through setup? (maybe the led's bad)
