mkartye
Oct 27, 2016Aspirant
WN3000RP lost connection to router
My WN3000RP range extender has worked great for a couple of years, but now for some reason it no longer connects to the router ( NexusLink 5631 ). It still puts out a strong signal but has no interne...
- Nov 04, 2016
I've decided that the problem is not with the extender. I went to Best Buy and purchased a new one. I then spent 45 minutes on the phone with net gear tech support and still could not get it to connect. I'm gonna bite the bullet and get the Geek Squad to come out and troubleshoot..
DarrenM
Oct 31, 2016Sr. NETGEAR Moderator
Hello mkartye
I would try to factory reset the extender you will want to hold the reset button for 10 seconds then you can try the setup again.
DarrenM
- mkartyeNov 04, 2016Aspirant
