Ethan11
Dec 28, 2016Follower
WN3000RP No Internet, Secured BT WiFi
Hi, i have had the WN3000RP for 2 years and it has been fine since i switched to BT. Now it says on my devices No Internet, Secured
i dont know much about the static stuff that is ioin the other discussions so could i have an easy explanation on how to fix it please
Thanks,
Ethan
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Ethan11
Have you tried to factory reset the extender by holding the reset button for 10 seconds and then try to do the setup again.
DarrenM
