Justcherryterri
Aug 31, 2015Follower
WN3000RP not able to connect to new pc but shows full strength
I just bought a new HP Stream 11 laptop that came with Windows 10. I am able to connect to our main router but not to extender even though the wifi shows full strength. It says gateway not available ...
nhann
Sep 04, 2015NETGEAR Employee Retired
Hi Justcherryterri,
Which WN3000RP version are you using? v1, v2, v3 ?
Is the extender updated to latest firmware?
Are you using the same SSID on the extender as you have it on the router?
Can you 'forget' the Extender network profile on your PC and then reconnect to the Extender?
