sjwtrip2
Jul 23, 2015Follower
WN3000RP Support
I purchased the WN3000RP WiFi RangeExtender about a year ago. The device set up easily and worked without any issues up until a few weeks ago when it just stopped working. I have been trying to conne...
nhann
Jul 28, 2015NETGEAR Employee Retired
Hi sjwtrip2,
Which WN3000RP are you using? (WN3000RPv1, v2, v3)
Have you updated your WN3000RP to the latest firmware? Has the WN3000RP been reset to factory settings?
Note: Do not upgrade the firmware using a wireless connection. Please perform firmware upgrade with “wired” or Ethernet connection only.
- Write down all the settings which you changed from the default values, since you may need to re-enter them manually.
- Download the firmware and save it to a convenient place such as your desktop. Unzip if needed.
- Log in to the device using a Web broswer. The URL is http://www.mywifiext.net.
- Click Maintenance > Firmware Upgrade
- Click Browse and find the file you just downloaded.
- Click Upload. While the firmware is loading, do not interrupt the upgrade process.
Let us know how it works for you.
NhanN
- dwittJul 30, 2015Aspirant
Hi NhanN, Im having the same problem as the person above. I followed your suggestion but cannot update the firmware because the extended is not working. It has no connection to the computer. The Netgear tech told me the software needed updating but wanted to charge to help me. Any other suggestions?
- nhannJul 31, 2015NETGEAR Employee Retired
Hi dwitt,
Are you able to connect your extender directly to your computer via ethernet cable?
Please try this wired connection and access your settings to update your firmware.
NhanN
