sjwtrip2
Jul 23, 2015Follower
WN3000RP Support
I purchased the WN3000RP WiFi RangeExtender about a year ago. The device set up easily and worked without any issues up until a few weeks ago when it just stopped working. I have been trying to conne...
dwitt
Jul 30, 2015Aspirant
Hi NhanN, Im having the same problem as the person above. I followed your suggestion but cannot update the firmware because the extended is not working. It has no connection to the computer. The Netgear tech told me the software needed updating but wanted to charge to help me. Any other suggestions?
nhann
Jul 31, 2015NETGEAR Employee Retired
Hi dwitt,
Are you able to connect your extender directly to your computer via ethernet cable?
Please try this wired connection and access your settings to update your firmware.
Let us know how it works for you.
NhanN
