Mekawi44's avatar
Mekawi44
WN3000RP v1
Can someone tell me if I can configure wn3000rp as an access point by connecting to my router using Ethernet cable? If not what would be the cost effective extender to support this function?
Thank you
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Mekawi44
    Yes you can under the Advanced wireless settings you can click a check box to make it a AP and then connect it via ethernet.
    DarrenM
  • Please note that my question is related to WN3000RP v1 not v3! Kindly confirm.
    Thanks
    • DarrenM's avatar
      DarrenM
      Yes the option is on the V1
      DarrenM
