sylrider
Sep 12, 2015Aspirant
WN3000RP v1h2 : impossible to see any wifi network
The wifi didn't worked well withmy repeter so I tried to re install it fdrom scratch. I turn it off and then on, then I go to http://mywifiext.net/ and firstly I was able to connect. I try to ch...
nhann
Sep 14, 2015NETGEAR Employee Retired
Hi sylrider,
If you are using a windows pc, please try to remove the old WiFi network profiles from your computer
http://windows.microsoft.com/en-us/windows/create-modify-network-profiles#1TC=windows-7
For Mac:
Go to System Preferences -> Network.
At the top of the Network pane select "Airport" from the "Show" drop down.
Select the network you want to "forget" and click the minus button at the bottom of the window.
Click "Apply" to confirm your selection when closing the window.
Please see page 27 of 32 to reset your extender to factory defaults:
http://www.downloads.netgear.com/files/GDC/WN3000RP/WN3000RP_UM_1Feb13.pdf
Please also note that changing the WiFi name of the extender to be the same as your router is not recommended for performance.
- sylriderSep 21, 2015Aspirant
Apparently it worked after a while but I don't know exactly why or how.
Thanks anyway for your help!
So it is working now, but apparently it's impossible to have the same Wifi name in order to keep the same wifi network everywhere in my house, so when I move from a room to another, I have to change wifi network everytime... ANy idea about that?
- nhannSep 21, 2015NETGEAR Employee Retired
Please see this discussion linked here: https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/is-it-really-extending-the-Wifi-or-create-a-new-one/m-p/973739#M9858
