nlm
Apr 20, 2016Aspirant
WN3000rp v3 compatability with BT Hub 5 Type B
Hi,
I'm trying to link my WN3000rp v3 range extender to my new BT Hub 5 Type B, but so far I have had no success.
A month or so ago, I changed from a Hub 3 to a Hub 5 Type A, and all worked fine with the range extender.
However, after experiencing problems with the Hub 5 Type A, BT have sent me an Type B, and I assumed that the range extender would pick up the signal and work as normal. That's not the case, and I am beginning to wonder if the WN3000rp v3 is now not compatable.
Has anyone had a similar issue?
Thank you!
You will need to reset the extender to factory default and reconfiguire extender, as you are connecting to a new base station.
- netwrksMaster
- nlmAspirant
Perfect! Thanks very much! Once I figured out that the extender had to be "on" when pressing the factory reset button (!), it's working fine.
Thanks again.
