kiwimike
Apr 28, 2013Aspirant
WN3000RP WiFi Extender issues (another!)
Hi,
I am unable to access the internet when I connect to my WN3000RP WiFi Extender.
Here is my set up:
WN3000RP V1.0.1.34_1.1.46
WPA2-PSK [AES]
Region Australia
MAC Address Wireless access control on (with all my devices added to it)
WNDR3700 V1.0.7.98
WPA2-PSK [AES]
Region Australia
I have the WN3000RP set as a static IP address on the WNDR3700
I can connect to the WNDR3700 wirelessly and access the internet.
I can connect to the WNDR3700 wirelessly and access the settings of the WN3000RP. This suggests to me that the ACL is set up correctly.
I can search for the WN3000RP wirelessly, but I fail to connect to it. I am using a Apple Mac, and the wireless status simply states "Alert: No Internet connection"
Any ideas how I can get this to work?
Regards
Mike
Here is my set up:
WPA2-PSK [AES]
Region Australia
WNDR3700 V1.0.7.98
WPA2-PSK [AES]
Region Australia
Regards
Mike
- masticInitiate
BeSpecific wrote: I just answered something similar to this is another thread. I also have a Mac. My problem started as an IP issue, then I resolved that only to not get internet access. This is a copy of the post from the other thread. Hopefully it will help you, too.
Ah, NetGear. Instructions that are accurate and specific would be such a help... alas, this will be the last NetGear product I buy -- and I still may return this, based on the plethora of posts regarding your idiocy.
HOWEVER - I did get this problem fixed. For now. I have a WEP password connection, so if that's what you have, follow this...
1. Reset your range extender by gently pushing down on the reset button (located by the power buttons) for about 20 seconds. Unplug. Wait a couple seconds, then plug back in. I also reset my router, just to be starting fresh.
2. Follow the Option 2 instructions in the Installation Guide (funny title, that) UP TO BUT NOT INCLUDING STEP3.
3. For STEP 3: Select the Wi-Fi network as directed.
THIS is where NetGear screwed up...
Enter the security passphrase for the existing network ON THE KEY 1 LINE (NOT on the PASSPHRASE line).
Hit Continue.
4. Continue following the instructions. Hopefully that will fix your problem as it did mine.
It's that one little lack of specific information in Step 3 that has so many people all screwed up and is probably costing NetGear a lot of customer goodwill/money, etc.
I just fixed this today and hope that I get a working range extender tomorrow when I wake up. If not, it's going back.
Good luck!
And NetGear... get your head back out into the sunlight...
Excellent response.
I didn't even have to reset the extender I just followed step 3 and behold I can connect to the internet. Netgear sure could incorporate your instructions into there manual it would have saved a lot of people hours of frustration.
Thanks for the info. - GreginLondonNoviceEncouraged by Charm's instructions after three failed attempts to get the Wifi extender to connect properly I followed the instructions faithfully, but time after time after completing the set up, the connection to the internet wasn't there. I've wasted 5 hours on this crock of crap on a Sunday - not blaming Charm - it's the last time I'll buy Netgear stuff, I had problems years ago with some Netgear stuff, but assumed as they were still in business I must have been unlucky but reading other posts here it seems it's not just me. No support anywhere from Netgear themselves, it seems, at least not on a Sunday but doesn't look hopeful for the week either. By support I mean someone on a phone who isn't going to charge £££$$$$ for helping a customer get something to meet it's claims on the box!
I've factory reset the extender several times and had many attempts to get the connection to mywifiext.net just simply 'fail' because there is no connection to the internet (even though I've seen Skype contacts pop up in the bottom of the PC screen). Despite this I've tried again and again to set it up, but nothing doing. I give up - It's going back to the shop. An afternoon of my life I wont' get back. :mad:charm wrote: Hi,
I think you don't need to set the WNRP to static.
You can do the reinstallation by this:
>hard reset the extender by pushing the button and holding it down for 10secs
>plug it in
>with your computer, connect to the network name NETGEAR_EXT
>your Netgear Ginie/smart wizard will automatically appear in your browser
>if not, please open a browser and type in your address bar mywifi.ext
>you should be able to access the extender's interface called Netgear GInie/Smart Wizard
>automatically it will search for the networks available
>once the search is compleate, you will on the list your own network name (if not, click on REFRESH BUTTON)
>tick on your network name> continue
>you will be redirected to step 2 (APPLY SECIRIty)>CLICK ON THE the KEY 1 box (this is under 2.4 ghz)
>hit on CONTINUE button
>on stEp 3 (CONFIGURE EXTENDER) You will be on the page that says " enter the settings for extender network" tick on the check box that says "USE THE SAME SECURITY AS THOSE FOR THE EXISTING NETWORK then click CONTINUE (it will then load and a pop-up window will appear that says: the extender network has been changed........)> click okay
>all the way, it will move to the last step and you can close the Interface that time
>Go back to your network names at the bottom of the screen where a STAIRCASE icon is, next to your time
>you will see there your network name this time with an _EXT suffix on it
>connect to that using your wireless device
>it will ask for a pass phrase, enter the same passphrase as in your main network
NOte: There is no need to set anything to static IP
Hope this helps,
CHARM :) - jsebastianNoviceI have the same problem. My questions is: how DO you set up the Access Control Lists?? I have an iMac. thanks.
Anyway I did a factory reset of the repeater, and re-set it up and ended up with the same issue.
After some more playing around I have now eventually gotten it working. What was not clear from the instructions is how to properly set up the ACL (Access Control Lists) for Wireless.
As well as adding the MAC address of each device that you want to allow connection to on both the WNDR3700 and the WN3000RP. You also have to add the virtual MAC address as shown on the WN3000RP attached devices list to the WNDR3700 router. It's a bit of a pain to have to add 3 MAC addresses every time you get another wireless device, but it seems to work.[/QUOTE] - jsebastianNoviceso how DO you "set up the Access Control Lists for Wireless" i have a verizon (actiontec) router and an iMac. thanks.
"Anyway I did a factory reset of the repeater, and re-set it up and ended up with the same issue.
As well as adding the MAC address of each device that you want to allow connection to on both the WNDR3700 and the WN3000RP. You also have to add the virtual MAC address as shown on the WN3000RP attached devices list to the WNDR3700 router. It's a bit of a pain to have to add 3 MAC addresses every time you get another wireless device, but it seems to work." - rja98006Novice
kiwimike wrote: Hi,
Here is my set up:
WPA2-PSK [AES]
Region Australia
WNDR3700 V1.0.7.98
WPA2-PSK [AES]
Region Australia
Regards
Mike
I just bought a Universal WiFi Extender WN3000RP and I need technical support.
Do you know anyone that can assist me or point me to someone that knows who can provide support for this device? Your help is appreciated. Thank you. - manojmanu18NovicePlease use the below link to resolve this issue
http://kb.netgear.com/app/answers/detail/a_id/19887/~/wn2500rp-faqs - speedtestguyAspirantTry making your main router use N-Only instead of mixed mode.
- SvavarAspirantThanks BeSpecific! Your instructions saved the day!
- PkeelanAspirantI need to install from factory settings but can't find the guide... Where can I view one?
- DarrenMSr. NETGEAR Moderator
Hello Pkeelan
Here is the user manual for the WN3000RP
http://www.downloads.netgear.com/files/GDC/WN3000RP/WN3000RP_UM_1Feb13.pdf
DarrenM
