Omuro
Dec 29, 2015Aspirant
WN3000RP will not connect to mywifiext.net
I purchase the WN3000RP wifi extender and the initial connection setup happen without problems, I used the existing network name as well the password everything seemed OK but when I verify at my wifi...
Babylon5
Dec 30, 2015NETGEAR Employee Retired
That message (which is Internet based) usually means that whatever device you are using to attempt to access the extender admin pages, is currently wirelessly associated with another access point (typically the base station).
Omuro
Dec 30, 2015Aspirant
Babylon5; thank you for your input in my dilemma-solving efforts, I know that you want to help me and I will say to begin that I didn't understand what it means "base" after I connected the range extender into the wall electrical outlet and connected it (two green lights came on) as I understand one is the extender is connected to the router and the other one you are connected to your device, then that means I'm connected also my smart tvs Netflix doesn't buffer anymore but the mywifiext.net says "you are not connected to your extender network" please help me understand what is in reality going on (please forgive my ignorance, I a computer illiterate) thank you! HAPPY NEW YEAR!
