Omuro
Dec 30, 2015Aspirant
WN3000RP will not connect to mywifiext.net
I purchase the WN3000RP wifi extender and the initial connection setup happen without problems, I used the existing network name as well the password everything seemed OK but when I verify at my wifi...
TheEther
Dec 30, 2015Guru
If you are trying to log into the WN3000RP via Wi-Fi, then you must be joined to its Wi-Fi network in order for mywifiext.net to work. If the extender is broadcasting the same SSID name as your main router, then a Wi-Fi client has a choice between joining via the extender or router. If a client joins via the router, then mywifext.net won't work.
If you didn't wire the WN3000RP directly to the main router, then you can connect a computer to the extender's Ethernet port. mywifiext.net should work.
- OmuroDec 30, 2015Aspirant
Hi. TheEther
Thanks for your reply. I must say I don't have a computer only one iPad and Smart tv. I'm a brain stroke survivor living in a institucion with out ace to the router I'm paralyzed with very little help. Please say things in plain English because I'm computer illiterate, please try your best. Thank You.
