prstn496
Nov 24, 2018Follower
WN3000RP won't connect to internet
My extender was working with our previous router. Our cable provider replaced the old router (they provided) with a new one, then set up our wifi for us. The network name was changed and now I can't get the extender to connect. I'm not saying the new setup caused the problem its just when it started. Anyway, I've gone through all setup procedures a number of times but I still can't get it to connect. When I used the WPS procedure, the light on the extender started flashing green but after a minute or so just turned off.
Any suggestions? I'm not really tech savvy but can handle most instructions.
1 Reply
Try resetting the extender again, and then connect to the NETGEAR_EXT network. Then browse to www.mywifiext.net in your browser. You should be prompted for a username/password. Enter admin and password.
After that, follow the "Use the Smart Wizard to Set Up the Extender" on page 9 here: http://www.downloads.netgear.com/files/GDC/WN3000RP/WN3000RP_UM_1Feb13.pdf
Next time, tell them to match the network name and passphrase to the old router. That avoids the need to change the networks on all your devices.
