Mamiluz
Dec 09, 2016Aspirant
WN3000RPv2 Connection Issues
I brought my extender to Tennensee while visiting daughter. I visit her often and my room is upstairs on the other side of the house and modemn. I cannot seem to get the Netgear_ext up on the netwo...
Mamiluz
Dec 16, 2016Aspirant
I reread your comment and I cannot get the extender to connect to the router.
- DarrenMDec 20, 2016Sr. NETGEAR Moderator
When switching the extender to a new router you will have to factory reset the device by holding the reset button for 10 seconds while plugged in and then do the setup again. You may want to do the setup right beside the router then move the extender to where you need it.
DarrenM
