Franztini
Sep 30, 2015Aspirant
wn3000rpv3 boosted a neighbors open wifi
I have successfully setup my extender to my secure wifi network. When I scan available networks I noticed that the extender is also boosting my neighbors open wifi signal. How do I stop this from o...
doraemon
Sep 30, 2015Prodigy
you shouldn't be able to boost someone elses wifi unless they know the wireless password used on the router?
Franztini
Oct 01, 2015Aspirant
That is the problem. My neighbor's wifi is open - no password. Lets say his wifi SSID is 'oldman'. If I don't have my extender on, the only wifi network that shows up is 'oldman'. As soon as I turn on my extender, I get my wifi extended as well as 'oldman_ext'. Since it is an open wifi anyone can use it and drag down my connectivity, hence why I am asking the question on how to stop this...
- nhannOct 01, 2015NETGEAR Employee Retired
Hi Franztini,
Please consider changing your router's password.
Please also reset your WN3000RP back to factory defaults (page 32 of 43):
http://www.downloads.netgear.com/files/GDC/WN3000RPV3/WN3000RPv3_UM_2Sep2014.pdf
and set up your WN3000RP to connect with your router.
On your router settings, you can also change the WiFi channel
http://kb.netgear.com/app/answers/detail/a_id/23783/~/improving-2.4ghz-wireless-performance-by-changing-channel- FranztiniOct 04, 2015Aspirant
Thanks I did the factory reset which made me find out why I thought I was boosting the neighbors wifi. This is funny. With a factory reset, the password is "password". Well I logged and went through the setup process only to realize that my neighbor not only got a Netgear extender within a day of me...but he left his extender at factory defaults so I was actually logged into his extender. What are the odds? Anyway, I got the answer in a very round about way that my extender was not boosting his signal. Thanks!
- nhannOct 05, 2015NETGEAR Employee Retired
Great! Glad you found a solution :)
